mgramann
- 0
- 0
- Waukesha, WI
Hi all,
After some searching, and coming up empty handed, I figured I would ask.
My M1009 recently started acting strange while making turns. Sometimes when I turn the wheel, it doesn't start to steer the vehicle right away. It feels as if the front end "shifts" and then starts to turn.
I jacked up each front wheel, and did the kick/wiggle check to see if there was obvious slop in the ball joints, steering linkage, or tre's. Everything seemed tight.
I did notice the leaf spring bushings were cracked a bit, and some leaf's not perfectly "aligned" but am not sure if that is related, since they looked that way long before this issue started.
Any ideas on what it could be, or how I could diagnose the issue? I'm mechanically minded, but I'm stumped on this one.
