portert0224
- 0
- 0
- West Point, VA
The GM P/N for the modulator valve is 359917. Does anyone have a good replacement source for these that still allow the stock line nipple to fit into the modulator nipple?
AAP had a replacement, but the modulator nipple was not large enough for the metal vacuum tube nipple to fit. Connecting the two with a vacuum hose sounds simple except my vacuum tube is at an awkward angle to use a rubber vacuum hose. What is everyone else doing?
Second question is: Can the shift speed be adjusted with a screwdriver when the modulator valve is out? On the aftermarket replacement modulator valve that AAP tried to sell me has an adjustment screw in the nipple. The stock modulator valve did not have the adjustment screw in the nipple.
Thanks in advance.
Thanks in advance.
