M1009 turbo build
remote6
Kenosha Wisconsin
cucv turboed first start
Here is a video of my m1009 cucv it's the first start up with my new 6.5l turbo installed, it's been a work in progress for about 3 months. Fast foward to about 8 minutes to see the start up.
paladin1176
Durham, NC
Spent a lot. Its the small things that really add up. Have not drove it yet its not done! Im hoping tomorrow!
Turbo intake manifold 50$
Turbo with exhaust manifold 200$
head gaskets and head bolts 89$ I think
exhaust gaskets 15$ each I think only 2 used
intake gasket 12$
upper intake gasket around 10$
pyrometer with probe 90$
boost meter free! used
oil line 29$
exhaust pipe 118$ for down pipe
exhaust pipe for crossover 14$ so far have not finished it
two exhaust hangers the rubber pices 12$
exhaust wrap 50$
probably 100$ of randome stuff
fuel pump 30-60$ have not bought it yet.
I need a couple of hoses i had to cut idk what those cost yet.
So tomorrow I will have the crossover on and will have to hook up a fuel pump and change the oil and hopefuly will be starting it up!
Too bad you won't be in North Carolina any time soon. I have a complete 6.5l turbo and motor from a 1993 pickup and I want to do the same thing. Not that I am scared of doing my own work...but knowledge and help are invaluable tools. Not only subscribing...reading in detail to prep for the after winter upgrade.
FMJ
37
Las Cruces, NM
I don't know what the final drive of the 4L80E is, but 3.08 gears in the 1009 Blazer keep the rpms way down, adding an overdrive transmission would seem to me to be overkill unless you re-gear to something like 3.73
2cents
fastbuckink
philadelphiha PA
I think OD is .75. I was thinking it would be great on the highway with the 3.08 gears, unless there is a glaring problem like the engine not having enough power or something.
FMJ
37
Las Cruces, NM
I think that will be exactly it, even with a turbo I think your going to be lacking power. Again these are my opinions, your mileage may vary!
367
Castalian Springs, TN
Look at the gear spacing / ratio between the 700r4 and 4l80E... i think you would be better off with the 4l80e... IMHO... i recently picked up one at a scrap yard for $50.00 and its gonna cost 75.00 to have it gone thru...
remote6
Kenosha Wisconsin
Yeah it was 112 but I kept looking and fond a sale I guess. 1450 is pretty high! No problems? I haven't drove mine too much think I only got it to 800. I need to put a lift kit on because my front drive shaft is hitting my crossover and denting it.
remote6
Kenosha Wisconsin
Yeah its not too hard of a job the worst part was getting the exhaust header bolts in. An idea I had after I was finished of course is if your taking the heads off is maybe put the headers on the heads before you put the heads on.
mcsteffensr
Las Vegas/NV
I would go with the 6.5 injectors because of the shorter length. it will keep the injector lines farther away from the exhaust manifold. that thing will heat up to about 1100 degrees! I had to insulate my lines because the fuel started to boil in the injector lined after a lot of high boost and hi temp runs... it was not a good thing. I thought I had blown the engine. I used a ultra high temp hose insulation I got from a hose shop. I also switched to 6.5 injectors. no problems since.
mcsteffensr
Las Vegas/NV
Turbos actuals lower egts and improve engine cooling. I know it sounds crazy but I tested it before and after on my CUCV. because I wasn't quite convinced. my truck runs cooler now than pre turbo install.
