CROM
- 0
- 0
- Des Moines, IA
Over the past few weeks, my truck has been starting with more and more difficulty. I chalked it up the weather getting colder, but now I can't get it to fire at all. I followed the TM on "Cranks but will not start" and have a few questions.
I have half a tank of gas. I did an ohm check and found five bad glow plugs and replaced them. Still no start.
I am able to bleed with fuel filter with ease which should eliminate the fuel pump and lines as the culprit?
I get all eight glow plugs clicking and the wait light comes on and turns off like normal.
I have done the dogghead starter relay mod and voltage/load tested both batteries (both of which are charging now after attempts at starting)
My question has to do with making sure the fuel system is operating correctly. I understand that I would not be able to bleed the filter if the pump was not working but the tech manual mentions checking the fuel supply and return lines for problems. Is bleeding the filter a good check of this or is there more I need to look at?
Also, in a few related threads, I have seen a fuel drain back check mentioned in turning but no starting issues. How do I check/repair this issue?
Any help you gents could shoot out is, as always, most appreciated!
Oh, forgot to mention, I have a lower radiator hose heater that worked like a champ for me all last winter and still heats up now.
