CUCVmike
- 0
- 1
- Somewhere, TN
My M1009 the last few days when the temp. has been 89 and 91 degrees wont start after sitting in the sun all day while I'm at work. The motor won't crank at all and the engine is cold (90 degrees) from sitting all day, I don't think its a starter, ignition switch, or ignition lock cylinder as I replaced them a year ago and only have 2,000 miles usage since. I still had occasional issues after replacing them so I zip tied the wires tight on the ignition switch and made it all last summer with no more issues. If I have a bad wire would just the air temperature cause the ignition switch to not function? Not sure where to proceed in solving the problem, appreciate any advice or be glad to give any additional information I forgot to mention.
