I have bought a surplus M101A1 3/4 ton cargo trailer but I'm having problems with the lunette eye and my truck's pintle hook binding on turns. It seems to happen mostly on right turns and it was bad enough it bent my pintle hook's mounting plate that connects to my receiver. It also slightly bent the lunnette eye draw bar. I was told by my local trailer supply store that the pintle hook may be too small in the pintle hook crosssection. I have a Buyers 8 ton pintle. They told me that this trailer's lunett eye is a 3" id which is larger than what is needed but it connects to the military's other larger vechicles. I wanted to see if anyone else has had a similar problem or if there are any suggestions. I can either get a larger pintle hook, try to change to a smaller lunette eye (if possible?) or get this combination to work.
Thanks
Thanks
