- 34,012
- 1,808
- 113
- GA Mountains
See above in living color. The white wire in the 4 flat needs to be grounded to the trailer chassis. Offset tabs on the bulb? Sounds like an 1157 not an 1156. The 1156 and 97 are the correct bulbs, I've used them dozens of times. You can use a 1003 bulb for a running light too but it's just too bright in my opinion. Later, as funds allow, look into the LED lights, they work great at both voltages. If your light housings are metal, use a dab of antiseize on the screws when you re-assemble. If the connectors fight you it should be a 30 minute job, if they don't, 10 minutes.Guys, the quiet lasted about 15 minutes and then the screwdrivers and F-bombs started flying!! The electrically challenged is in full effect. Here's what I have.
1. To start, the bulb I pulled out has two nipples that are even. The replacement 12v bulbs are offset and won't fit in the holder. Wrong bulb?
2. I have a 4 prong flat harness going back to the trailer. Wire colors are:
White, Green, Yellow, Brown and a Black. Is the black same as a Brown? if so, I'll grab a new one if it helps my stress level. I count 5 colors there. Thats a 5 flat for use with cars that have seperate brake and turn signals.
3. Wires on the trailer do not match some of those you sent. Here's what's on it.
- 22- 460 Green Wire
- 22-461 Yellow Wire
- 21 Brown Wire
- 23
- 24-463
- 24- 464
my screwdriver thanks you as do my neighbors.....
