m101A2 master cylinder help!!!!
rogerm101a2
ohio
hello,
i just picked up my m101a2 and the top of the master cylinder was smashed down... So i was woundering where i can get a new one or can i rebuild this cylinder. It looks like where its smashed it can be unscrewed from the cylinder. thanks for your help!!
gizip
Tappahannock, Va.
Master Cylinder for M101A2, M116A2, M101A3, M116A3 is part number 10614 Actuator Master cylinder from Croft Trailer Supply, phone 816-861-1001. Last one I bought was $83.79 in Nov 09. Comes with standard metal cap. Military vented dome cap is part number 850279, cost was $47.55. They also have shock absorbers (32247) and all small parts to rebuild this actuator made by Balcrank . Happy trailering.........Wayne Walker
txm37
Waxahachie, Tx
I actualy found a cap that fits the master cylinder from a late 50's Chrysler in a junk yard. (free) Does any one know where to get a rebuild kit for the master cylinder or if they are even available? $83 to $100 is a bit high to me for a master cylinder.
jeepin
11
Vermont
Ask for rebuild kit for a 1960's CJ5. The MC interchange as does the rebuild kit. Just make up a year they would be all the same from 59 ish to 1970 ish. I pick mid 60's because then the dolts at NAPA can find it in the book.
Krempely
Simpson 5M9
23
Tennessee or BUST
1989 M101A2: I've been researching a master cylinder (part number 10614) rebuild kit all day. Found a rebuild kit from Autozone (part number 22976) for $15. I specified a 1964-66 Jeep CJ5 and the parts kit appears to be the same. 1967 and newer Jeep CJ5 kits will not work. I will know for sure Monday when it arrives.
M1009
M1008
M35A2
M105
M101A2
M135
'43 MB
Krempely
Simpson 5M9
23
Tennessee or BUST
03/23/2010: The master cylinder rebuild kit (Autozone 22976) worked great.
borg
Perry/UT
Autozone 22976 kit
Thanks used the $15 repair kit saved me from buying a new master cylinder for $136. Noticed you can buy the Jeep master cylinders on ebay for about $40. Looks like it would bolt right in for a full replacement. Anyone know of a cheap surge shock replacement?
