M101A3 / M116 Master Cylinder Cap ?
blybrook
Fairbanks, AK
All,
I've searched through the threads and have only found a reference to a replacement cap being available from a mid 50's car. Is there a better reference that I can utilize when I go to the parts house or the junk yard?
The reason I ask is that I'm looking to build a power bleeder for my M101A3 trailer since I'm adding a section of flexible brake line after finding a slight leak in the line at one of the drums while working on it this weekend. aua
I have the TM part numbers and took the cap to my local hydraulic shops. They cannot match the threads to get a reducer built. I figured they would be my first shot to get it done.
Mainly I'm looking for a replacement cap so that I can cut / drill it for the brake bleeder assembly I'm fabbing up using a nalgene bottle & 1/4" line. Trying to do it cheaper and faster than getting it through one of the regular vendors.
Thanks in advance.
Bill
doghead
4 Star General /Moderator
1,178
NY
Try a jeep cj2,3 or 5 master cyl cap?
AceHigh
30
Princeton WV Lake City FL
I just bought a replacement master cylinder from Crofts. It had the small "civilian" cap so I retained the bigger OEM one. The smaller cap is in the photo below.
Let me know if you need this one sent or if you can get one locally, if the small one will work for you. The big ones are harder to get. :p
blybrook
Fairbanks, AK
Thanks for the information fella's. I'll see about running these down. I tried Napa last night with no luck, but have yet to make it to the parts yards.
AceHigh, if I can't find it, I'll let you know.
Thanks again.
Bill
