M1031 CUCV transfer case (NP241C)
drbeeper17
13
San Diego, Ca.
First, I realize this probably isn't the place to "sell" items. But, the NP241 that I have is from a 1989 3/4 ton Suburban. It's used and a bit dirty still so I am asking $275 for it. Everything shifts good on it. Since it seems you had a NP208 in the truck, this will bolt directly in place, you don't need a new shifter. Also your speedometer cable will screw in. If you really do need the shifter, I have one for it. The only difference in the shift levers is the actual metal piece that bolts to the transfer case. The clocking is about 90 degrees off between the NP208 one and the one used on the NP241, but you would never know this unless you unbolted that piece.
