Where should an M105 bed be in relation to the back of the frame and pintle hitch on a deuce? My frame is not shortened. Should the rear gate be able to fold clear down and not hit the pintle? That would require that the bed stick 9" minimum past the frame. Should the bed be even with the frame or a couple inches past, where the gate would have to be restricted to laying flat, or hitting the pintle would dent it?
The distance from the back of the bed to the center of the wheel well is 50" which will determine axle mount and spring perch location.
