- 2,074
- 873
- 113
- UT
OK, I'm a total idiot....as far as the 3/4-inch round LED marker lights go, when I mentioned that I couldn't figure out how to fit the rectangular connector plug through the 3/4-inch diameter hole drilled for the light to fit through, I just had a Homer Simpson realization: the rubber grommet around the marker light can be slid down the wiring, so you can install both the marker light and the grommet through the mounting hole separately, then installed from the front with the wiring already through the hole. Good grief....
So if you wanted to keep the connector plug for easy light removal/replacement later, you could.
Here's how I wired them and where I ran the wires (in parallel, just soldered the positive [black] lead to the brown wire of the trailer's 4-wire harness and the ground [white] lead to the white wire of the trailer harness):
