- 8,280
- 655
- 113
- Corpus Christi, TX
Is it a M106 or M1061?M106 Question:
I purchased a M106 recently. I have to travel about 500 miles to pick it up. I plan on using a 3/4 ton pick up truck.
Because the unit has Air / over Hyd. brakes do I need to have air in the system to tow it or will the wheels spin freely? I already have the rear lighting figured out ( using magnificent towing light strip).
When I return home with the unit I plan on converting to Electric / over Hyd.
Here is where the tough call part comes in.
Since you failed to follow registration instructions and we have no clue where you live in the United States, anyone on here would have trouble making that decision.
If the 500 mile return trip is exclusively at a very gentle uphill where the vehicle is pulling the whole time AND it is rural with absolutely ZERO traffic that you can run into AND absolutely NO chance of fuzzy or furry little creatures crossing your path AND the power to weight ratio is sufficient as well as the truck braking power to GVW is sufficient in congruence with the grade to enable the legal stopping length AND the trailer has proper license AND if you have a tailwind the coefficient of that could affect this.
But there is another factor here.
Will your insurance tell you to go pound sand when they see what a stupid (not allowed the next word) maneuver this would be.
Now I'd suggest reading up on the trailer and it's GVW. Face it, you didn't step off on the wrong foot with your first post, you did a hand stand instead. You may want to pull back and reintroduce yourself and the situation and reengage under more favorable circumstances.
So endth the lesson.
