Billydeuce
- 14
- 3
- Sebastian, Florida
want to sell it?I have a regulator
How much are you looking to get for it?I have a regulator
Will a N1228 alternator fit the 1078We have three lmtvs all with bad alternators. Two of the m1078s have had them replaced in the last three years. I have sent two of them to neihoff authorized service centers and the parts that have failed are sealed in epoxy meaning can't be serviced. Spoke with neihoff directly. Any alternators or parts have to be purchased through a distributor and must have clearance from d.o.d. which takes 18 to 22 weeks. This is what I was told by neihoff. Honestly I wouldn't want to be on a trip with this truck and have an alternator failure again. Not worth the headache. I sleep easier knowing Napa will have repair parts. Regardless, for those interested i will post the information aboutbthe company im workimg with and pictures as soon as I have the aftermarket unit installed. Unit will be a direct bolt on with filtration. And you will not need the charge controller located by the spare tire.
Thank youLeece Neville commercial 200A 24v.
Requires an 80-100A 24-12v converter like a Bussman. View attachment 897773View attachment 897774
Thank you I also found a 12/24 Delco Remy 30siWill a N1228 alternator fit the 1078
Just need to figure out the wiringJust need to figure out the wiring
Did you ever figure out the A1 mounting?Leece Neville commercial 200A 24v.
Huh? Acela builds trucks, yes. What are you getting at exactly?https://www.acelatruck.com/?fbclid=IwAR3otQIi0y_7lRfZqJ_Vuh_x3uv36A9tWVB37VTGbcn_wjugHReC26sgm5c
They are going to have a store that sells M1078 an the 5ton one
They used to sell parts, but stopped as far as I know….. my understanding is they only support their customers now.https://www.acelatruck.com/?fbclid=IwAR3otQIi0y_7lRfZqJ_Vuh_x3uv36A9tWVB37VTGbcn_wjugHReC26sgm5c
yup.... dats true.They used to sell parts, but stopped as far as I know….. my understanding is they only support their customers now.
Never seen one of those before. The ID plate in one of your pics says made for Cummins. Delco discontinued production of the 30SI, but you could probably still get parts for it, well maybe not for the dual volt circuitry/control portion… I way prefer commonly available/in stock, to expensive unobtanium…Thank you I also found a 12/24 Delco Remy 30si
