M1078 Won’t Start
JJFarris
Clovis, CA
I finally received our truck. When the truck went to load it, it wouldn’t start unless they jumped the starter. It wouldn’t move so they had to push it on the trailer. It had enough air when they got here, so I just released the brake and pulled it off. I replaced all the batteries, and it won’t start at all now, even when I jump the starter. It just turns over. I know nothing about these trucks, so any pointers would be greatly appreciated.
JJFarris
Clovis, CA
Yes has fuel. Either makes it want to start, but thats it. I've made sure there no water in fuel separator, and theres pressure from pumping. I'm still reading through all the other "No Start" threads. I have found a few things to try, but I'm still at a loss as to why it started by jumping across the starter a week ago and now it won't.
NDT
6,285
Camp Wood/LC, TX
24 and 12 volts present at the PDP power points? Instruments and trans selector come up when you power on the ignition?
NDT
6,285
Camp Wood/LC, TX
PDP is power distribution panel in front of co-driver. No surprise the engine does not fire if the ignition will not turn on. Sounds like you got the battery connections wrong.
Andyrv6av8r
455
Spartanburg,SC
Check that all relays are correct per the diagram on the cover of the distribution panel. Very important but overlooked step.
porkysplace
1,487
mid- michigan
I don’t understand what PDP means?
No lights work when I hit the green switch on dash.
TM 9-2320-365-20-3
section 7 cover's the PDP
Post #5 of this thread has a link to that section
https://www.steelsoldiers.com/showthread.php?124517-M1078-No-Start-Not-even-trying
The rest of the TM's can be download free here;
Listed below are a number of the TM's for the M1078 trucks. To save them to your computer, right click, select "save as"
m1078_TM 9-2320-365-10.pdf
m1078_TM 9-2320-365-10 for the M1078 series trucks.
m1078_TM 9-2320-365-20-1.pdf
m1078_TM 9-2320-365-20-1 for the M1078 series trucks.
m1078_TM 9-2320-365-20-2.pdf
m1078_TM 9-2320-365-20-2 for the M1078 series trucks.
m1078_TM 9-2320-365-20-3.pdf
m1078_TM 9-2320-365-20-3 for the M1078 series trucks.
m1078_TM 9-2320-365-20-4.pdf
m1078_TM 9-2320-365-20-4 for the M1078 series trucks.
m1078_TM 9-2320-365-20-5.pdf
m1078_TM 9-2320-365-20-5 for the M1078 series trucks.
m1078_TM 9-2320-365-24P.pdf
m1078_TM 9-2320-365-24P for the M1078 series trucks.
m1078_TM 9-2320-365-34-1.pdf
m1078_TM 9-2320-365-34-1 for the M1078 series trucks.
m1078_TM 9-2320-365-34-2.pdf
m1078_TM 9-2320-365-34-2 for the M1078 series trucks.
A good source on how to use the TM's;
How to use/read Technical Manuals
Pope
Montana
Model ID
Is yours an A1 or A0? The electrical is different between the two, and will make a difference in the diagnostics.
an A0 will have a 3116 mechanical CAT and the A1 will have the 3126 Electronic controlled engine.
