Overdrive
- 95
- 28
- Wentzville, Missouri
Can you describe the loose wire on the back of the relay? Pulled out of the back of the PDP or loose contact?It was a loose wire on the back side of the ignition relay
Sent from my SAMSUNG-SM-G890A using Tapatalk
I had my brake lights stop working and using the -20 found the brake pedal switch to relay didn't have contunity so I used a jumper wire in its place. I checked the connections on the back of the relay PDP panel but didn't see anything obviously loose. Just wondering if I missed a loose wire.
Thanks
OD
