M109 with Hercules Multi Fuel Engine Fuel Controll Assembly
Bellow is a re-post I posted in wrong section. I am reposting it here for background. But my current question is bellow
I lost the small stainless steel retaining clip for my M109 465-1 Hercules injection pump. I dissembled and removed the fuel control dowel and lever arm to clean.
Unfortunately, I did not note the position of the dowel in relationship to the lever arm. The assembly allows 360 degree assembly. Best I can tell from a picture, the control arm goes straight down and the small pin that fits into the end of the fuel control rod assembly should be at its lowest (down position) like the control arm.
I found a picture but it lack the resolution needed.
I have now installed the fuel control Assembly but I don't know how to know if I got it right. As this assembly is part of the shut off, I am afraid I could have a runaway motor if it starts. The assembly went in all the way and it seems to have the correct range of motion. If memory serves me, the fuel control control arm will travel freely from about 120 deg to 240 deg. Any ideas or insight?
Thanks
Philip
