I "think" I did everything by the numbers in wiring a 4 pin connector to the 12 pin male trailer end. I switched the 24 volt incandescent lights in the tail lights for their 12 volt counterparts. The LED and incandescent running lights and blinkers work. The brake lights don't. Is there a possibly simple reason and fix for this? I've googled and searched. No luck. I thought the blinkers and brakes ran on the same wire?
