dvdkea
- 0
- 1
- Albany, NY
I am in the process of converting my 1102 trailer over to 12v. I am following the post below and i have everthing working except for the running lights. When i hook the brown wire from the 4 wires coming off of the truck to the solid red wire I get no running lights al all. Even the running light on the truck go off. When the trailer plug is disconnected, the running lights on the truck work fine. I tried to connect the brown wire up to all the other remain wires and i get nothing. I have not replace the 24v running lights with the 12v number 96 bulbs yet. as far as i know, they should work on the 24v bulbs, but will be dim.
Any ideas?
If you have a military pigtail coming off your trailer, here are the color codes that correspond to the wire circut numbers. The wire colors are the indiviual wires that are INSIDE the outer black rubber insulation.
24-484
22-461 LEFT TURN/BRAKE RED WITH WHITE TRACER
24-483
21 MARKER LIGHTS. RED
23
90 GROUND BLACK WITH RED TRACER
22-460 RIGHT TURN/BRAKE BLACK
37
Any ideas?
24-484
24-483
23
37
