- 850
- 472
- 63
- blairsville ga.
Thanks for the link and thanks Clinto for sharing the idea about Y ing the civi pigtail in going to make that change. Trailer has the LED lights already.Here's another with bed replaced: https://www.steelsoldiers.com/showthread.php?159450-Another-M116-Mule-trailer
Having your own shop sure makes projects go smoother and faster,
Shear 3/8" X 10'
Brake 230 ton 14' bed, 12' clear, will bent 1/4" up to 12' long, 3/8" to 12' and 1/2" to 7'
Plasma 5' X 10' bed, we have cut 18 ga. through 1 1/4" mild steel, It will also do aluminum, Stainless, some alloys and can etch also. Tolerance is .016 and holes should be 1.5 X material thickness but we have done smaller.
Also have a 50 ton iron worker for pinching holes and a horizontal band saw that will cut a 12" square or 12" x 8" rectangle @ 45deg
X2.OK - now you're just bragging (not that there is anything wrong with that).
WOW! Nice Shop!
That would be complements of MR Zout he's an awesome fabricator, body man and painter, I am not a painter.X2.
Nice '09 as well, looks great pulling the mule hauler.![]()
