Rasmusrentals
- 17
- 3
- Murrieta, CA
When I engage my Transmission into any forward gear it goes to a higher gear, It doesn't start out in first and it doesn't upshift. If I am in high range it boggs so bad I can not really take off, If I put it into 4 low I can drive it but it doesn't shift up or down. Reverse works good, but in forward it seems like it is going into some sort of fail safe mode.
It is not the original trans, I can see that it was changed to according to the witness marks on the bellhousing adapter as well as the front drive shaft was not tightened at both ends and the belly pan was missing half of the bolts.
Does anyone have any info on them recalling and changing the transmissions? or any technical manual with troubleshooting ? The transmission does have a part number tag hanging from it. The Growler only has 67 hours on it and the Quality inspection tag from 2012 was still hanging from the windshield latch, so I don't believe they used it.
There is also some sort of breather mounted on the firewall, passengerside, that has a breather hose going to the trans and the transfer case. It is leaking quit a bit of fluid after I drive it. It appears to have a solenoid on it. Any info on that would be much appreciated.
