Diablo
- 13
- 3
- Kerrville, Texas
I have a 2007 M1165 non-REV that, true to form, is constantly running hot. Since I will not be putting JP8 or anything other than #2 Diesel in it, I'm looking to turn the temperature down a little bit. The coolant stack has been separated and pressure washed. I have installed a new 180-degree thermostat. I have flushed the entire system four (4) times. I'm seeing reservoir temps of 205-210, radiator temps at the upper radiator hose of 230-235, and thermostat housing temps of 210-220, as measured with an IR thermostat. The radiator and system is flowing well. When the fan kicks on, it drops it down to 180-190 all around. However, within 3-4 minutes of the fan shutting off, it's all right back up to the previous temperatures.
In my research, I've found a few things that can be done to bring the temps on the 6.5 NA or Turbo into more reasonable temperatures:
I have found a few places that have kits for H1s, and a few others with kits for HMMWVs. However, they are not in stock, won't fit the ECV/REV trucks, or are ludicrously expensive.
Has anyone attempted these conversions? If so, what fan did you utilize? Did you source your own parts, or did you go with someone's kit?
Please advise.
- Replace the OE water pump with the, high flow, balanced version - GM PN: 251-603
- Replace the fan clutch with a Hayden 2886 Thermal Clutch (non-Electric Duramax), eliminating the thermal switch, TDM and Cadillac Valve
- Replace the fan with a GM PN: 15-80690 from the Duramax.
Please advise.
