M1165 - REMOVING REAR WALL - METAL CURTAIN
4x4nutz
117
Mico, Texas
Removed all bolts, inset screws, and cut all the seals we could see to remove the rear wall, but rear wall not budging. Do we need to take off the entire top to get the rear wall off? Installing slant back. Thank you.
  • Like
Reactions: OBX
tgejesse
287
Maryland
Lots of GLUE is my guess. I removed that rear window close out in my truck and I had to peel and pry the thing apart after removing all the bolts.
Good luck that stuff is HEAVY
4x4nutz
117
Mico, Texas
I figured as much. Definitely some type of adhesive.
Awol
464
MA
Probably glue/adhesive as said above. Should come off with a little prying.
I wish you were closer to me, I'd love to have that curtain!
  • Like
Reactions: 98G
