Hello to all,
Recently I was bought an 45k Garwood winch from an M125 10 ton (M125s have an wrecker 45k lbs rear winch installed in the front with a smaller dia sprocket)...
I am trying to remove the shear pin (it was intact not broken) with no luck :
Even cotter pin was present , I have it removed and trying to remove shear pin , goes only about 1cm down and stuck , cut shear pin round head and try to remove it from this side but again the same , moves about 1 cm and then nothing...
Any suggestion , trick , tip , comment is more than welcome !!!
