- 1,171
- 29
- 48
- Galesville, WI
Any body have any good pics or info in a M211/135 deep water fording kit? I'd like to make one. Have searched but to no avail.
The cable is relatively easy to get (I have two), the later 3 push/pull cable is the hard one to find one. I also have 2 extra fording kits for a M35 or M35A1 but by the pics they look totally different. Acetomatoco used to have a complete kit. (don't know what happened to it or who got it).The gottcha if you want to build a kit is the dual push/pull cable control - this shuts off the crankcase vent/etc.
Other than the dashboard air intake, the rest of the fording kit should be close to the parts needed for any similar vintage M-series truck.
I have ridden in modified off road style trucks that use the intake in the cab approach for added water resistance, it isn't much different than leaning into the engine bay while someone hammers the gas pedal. I can only imagine what it would sound like in the cab of a deuce.So what, your wife asked you to take a shower and you thought this would be the easiest way?
But in all honesty isn't a bit inconvenient that the tubing has to be inside the cab? And idea what it will sound like sucking all that air in a few feet from your head?
How much sucking sound could a six cylinder with a 4" intake tube make?But in all honesty isn't a bit inconvenient that the tubing has to be inside the cab? And idea what it will sound like sucking all that air in a few feet from your head?
...with a governor and an oil bath air filter.How much sucking sound could a six cylinder with a 4" intake tube make?
