monighan
- 0
- 0
- Pittsburgh PA
I did a genset motor swap this week and it was very easy. It did take a little longer because I sand blasted all the ducting and what ever else needed cleaned up and repainted. These are the things needing changed; oil pan/windage tray,gear cover,bell housing,oil lines,flywheel,belt pulley,drain lines from the heads,intake runners and intake manifold,carb,mag,dip stick,fuel line,then add the Mule blower and sheet metal,exhaust pipe. Maybe I missed something. Even though it was alot of screwing around I did spend several hours of quality time with my 15yr old and he learned alittle more about basic mechanics and engines. If we need to do another one on a second Mule I'll probably just buy one from Bill W. to save some time.
