M35 powered by 5.9 cummins
mudguppy
15
duncan, sc
... as the deuce motor and a 6b cummins are roughly around the same size, correct. ...
6bt is quite a bit smaller than the MF; at least 6" shorter in length and almost 8" shorter in height (pan to valve covers).
you'd be on the right track with a medium duty donor - sourcing a non-intercooled one w/ a manual trans will make it as close to bolt-in as possible (similar motor mount arrangement, versus the pick-up truck arragement).
if you have other questions, just let me know and i can tell you what i did and why i did it.
:beer:
