M35A1 vs M35A2 ?????
298
Olean Ny
The -A1 didn't have a verticle exhaust.................Smaller tail lights.......... Naturally aspirated Engine........
Chassis and other parts should be the same....for the most part
acetomatoco
Yup... old Smokie.... the LDS427 with the horizontal exhaust... We could knock Comrade off his bicycle at 15 feet...cough cough.....
jatonka
87
Ephratah, New York
And the M35A1 was seriously turbo'd. The 427 uses a large turbo for power, not to clean the air. Mine is still going strong, drawing 8 to 9 tons of slate and gravel regularly. 2500 rpm max, check the oil and antifreeze, adjust the valves once a year. Runs like heck, smokes like h&%l !!!!!
DDoyle
80
West Tennessee
To my knowledge - there is no LD427. There is a LDS-427 - the first Multifuel, and the S standing for turboSupercharger. As John mentioned earlier - that turbo was to make HP - not clean the exhaust as was the case with the later LDT.
The M35A1 had a box seat - and so did the M35, and so did the M35A2 until about 1969 or so (have to dig through a lot of paperwork to pin that down closer.
HTH,
David Doyle
m16ty
218
Dickson,TN
This disscusion begs the question, Has anyone ever put a LDS427 turbo on a LDT465? If so what was the power increase?
1,810
Visually, the LDS427 turbo looks alot like the turbo that was used on the early LDS465 engines. Later versions and through replacement, the bigger 5 ton turbos got swapped out.
