Dasgog
- 148
- 43
- Tucson, AZ
Hello
I was wondering and hoping I was not looking outside the box on this one. From my experience you can not take booster pump off (2 long bolts hitting steering column) unless you take IP put it tilt engine. Unable to tilt engine and really don’t wanna remove IP 3rd time in 2 months. So.
Aside from a 7/16 socket and or wrench (both standard) are there any other cool or weird tools where I can TIGHTEN the bottom of the 2 bolts? I’m having seepage, not dripping, from bottom. It has a new o ring and I changed the 4 screw bolts with hex screws and everything is tightened nicely so either the machines metal just isn’t sitting regardless of what I do or I may have to tighten that bottom bolt.
suggestions?
suggestions?
