M35a2 paint job
harry
Robbinsdale/MN
scraped wirewheel and sanded ever thing ,feathered and smothed old paint ,dint try and remove good old paint wipe down with solvent , primed bare metal heavy, and paint primed lightly ,mix paint well and realy mix primer well
use mask good one ,cover all your skin you can, and eyes ,you dont want green.it dont wash off .
I used a spray gun top feed (can on top, HVLP ) think was the primer spray gun (larger spray tip ) came in set you need to put paint on primer within 4 hours (or sooner)
use reduser so you spray it on just wet . but be carefuf it will run , a rag with reducer and quick re spray will fix runs.have extra cans to put unused paint in . clean gun good I rinsed after priming and sprayed paint then cleaned gun good (MEK)
it is perrty forgiving , I sprayed black latter 60+days you could spray same day
hope this helps Harry
Bighurt
46
Minot, ND
hope u dont mind me posting this Harry.
(r click image and click open link)
Thanks, I posted the message without refreshing my browser, turns out page 2 and three were un-read at the time of posting...opps.
CARC is outrageously expensive at my Sherwin Williams, so a new paint job for me will have to wait.
RAYZER
59
sanford/florida
the carc type one is $75.00 per gal. at the sw store in tampa fl.they can ship it to a sw store in your area, the green. brown and black from the data sheet should match the orig. paint.
srodocker
69
Lacey, Washington
what type of primer should i pick up from a auto store? and being as i have no paint exp. whats reducer? as im going to be pumping out a paint job in a cpl days. how long did it take to paint yours just the green?
