M35a2 will not start
502NDMP
NH
Hopped in the truck, heard a pop and tried to start and then nothing. Ideas? Never had a problem in the past.
Elijah95
Certified Rookie
1,239
1,183
Georgia
I’d start with checking your battery voltage and connections, make extra sure every connection is good-n-tight or your terminals will turn into Roman candles (don’t ask)
502NDMP
NH
I assuming that it is electrical. Starter button, etc, definitely a power related problem. Batteries are fine, have fuel etc.. I pop I heard could have been a relay.
Elijah95
Certified Rookie
1,239
1,183
Georgia
Could also be a ground issue, battery box ground is common, and another thing to check is before you hit your starter switch, reach under and gently wiggle the wires while you press it. Had it happen to a truck
dmetalmiki
2,027
London England
My bet is the starter solenoid/s. Iv'e had so many go fuzzy it's not true. But usually just cleaning and re-wiring tight did the trick. (and some do have very tricky wiring circuits).
Aussie Bloke
373
Lost, out bush in OZ
G'day everyone,....
I had that 'POP' sound and found a melted battery terminal, turned out to be a loose terminal clamp connection.
Have replaced the clamps with non lead type.
And as previously stated, check your ground connections.
Its always great piece of mind knowing they are all clean.
Aussie.
