Dunkeye11
- 4
- 8
- Fairfax, Virginia
Upon installing my new 6TL batteries to replace my value power ones! I’m getting a short on the main positive power cable and it almost melted a new terminal off......
It’s the one that connects to the front harness. I started disconnecting things and testing it for resistance. I’m sure others have run into similer issues is there a common item that fails or shorts often that I can check I did most of the lights and the high beam switch and the turn signal box and primary light switch all accessories radios and convoy lights are disconnected
