Rezdeuce
- 1
- 0
- Valley center ca
I opened my raid cap too just check the coolant and it looks white is that right? And I want to change it anyways so what's the best coolant for the deuce thanks
The reason you were asked to check the oil was because oil in the coolant and coolant in the oil are hallmarks for a leaking head gasket. The water and oil passages in the engine block are well separated by the head gasket where they cross from the cast iron block to the cylinder heads. If the gasket fails in a spot, an oil and a water passage may become connected - contamination results.I opened my raid cap too just check the coolant and it looks white is that right? And I want to change it anyways so what's the best coolant for the deuce thanks
The operator's manual (hint, hint!) says that the coolant level should be visible in the filler neck when you take the cap off.GREAT POST. I also am new and was thinking about my coolant. what is the proper coolant and level? my temp gauge may be busted because it never seems to move. also my heater never throws heat, barley a warm breeze and that dosnt seem right
Affirmative for oil in the coolant. Possible head gasket. Possible oil cooler.Ok here is a pic of it so from what you are saying and the looks of it its a head gasket? Now how hard is that to replace and what coolant is the best sense I am going to have to drain and replace my coolant thanks
I cleaned the engine all up and there is some oil by the head how do I check the oil cooler? Thanks for all the helpAffirmative for oil in the coolant. Possible head gasket. Possible oil cooler.
I would investigate the oil cooler first, especially if you do not have suspicious oil leaks or oil seeps from the head gasket area onto the block. Others may chime in with troubleshooting suggestions.
thanks on the linkYou may want to check out this thread: http://www.steelsoldiers.com/deuce/59373-why-my-coolant-white.html
It has a diagram of the oil cooler, its location and a picture of the gaskets.
How much oil in the head area? A seepage of oil does not necessarily mean the head gasket is kaputt. Many multis (and other diesels) seep a little. With head gasket failure, you often get significant leakage that stains the whole side or rear of the block and comes back as quickly as you can clean it off.
Yes.will the oil cooler cause the same white milky in the rad?
