- 473
- 270
- 63
- NorCal
Hello,
Just finished mounting 395/85R20s and an electric fuel pump on the M35A3. Which left me without a reasonable way of putting the spare in the original location. But... plenty of room to hang a 2nd fuel tank. Anyone done this?
I can see taking the return line down the driver's side frame rail and using that as input to the 2nd tank. But hooking the 2 tanks together? Bernoulli says they'd both be at the same level as the lowest situated common connection... Eg, if I run a hose from the inside-bottom on the driver's to the inside-bottom on the passenger side both tanks would fill and then drain to that low level.
I guess I'd just need to find/make a clear path to run the intermediate hose and brush up on my aluminum welding skills.
Thoughts/input?
Thanks,
SJ/JD
Thoughts/input?
Thanks,
SJ/JD
