the buddah
- 1
- 8
- ocklawaha,fla
maybe some one can help with the noise i have comeing from my driver tire area it sounds like a squick at slow speeds any info would be helpful i just hope it is not a bearing issue
Has anyone ever tried Slime tubeless tire sealant in there a3's I used it in three of my tires that would go flat in under one day and now 2/3 of them hold air for more than 3 weeks and one still goes flat in about 2 days now.
Unless you removed the CTIS, there is an inline filter just before the elbow into the rim. Slime will booger that up.Has anyone ever tried Slime tubeless tire sealant in there a3's I used it in three of my tires that would go flat in under one day and now 2/3 of them hold air for more than 3 weeks and one still goes flat in about 2 days now.
I thought about doing this and decided against it. Slime works on the principal of centrifugal force pushing the slime against hole/punctures inside the tire. Most A3's have leaky tires because of the worn out O rings between the split rims or the grommets are bad. The centrifugal force would prevent the slime from working very well to solve either of these issues.Has anyone ever tried Slime tubeless tire sealant in there a3's I used it in three of my tires that would go flat in under one day and now 2/3 of them hold air for more than 3 weeks and one still goes flat in about 2 days now.
I haven't looked recently, but there have been complete NOS A3 axles for sale on Ebay in the past.All A3 owners.... I am on the look out for a front hub for my A3. I can find bearings and seals but hubs are no where to be found...Does anyone have any type of lead as to where i might locate a hub or even a complete A3 axle?
If you remove the CTIS, you can switch over to A2 bearings. Actually, there's an "Equipment Company" in Memphis that sells conversion kits...Does anyone know if you remove the CTIS can you use A2 bearings or do you still have to hunt for the expensive A3 bearings?
I have rear hubs, have not checked but should be same as front hubs. Have many other A3 parts. I need to put a hub off a front steer axle of an A3 to be sure.All A3 owners.... I am on the look out for a front hub for my A3. I can find bearings and seals but hubs are no where to be found...
Any and all info is much appreciated!!
Thansk,
Matt
Front, rear, or both?the A2 hub is the same you just have to drill and tab the air hole if you still use the C.T.I.S.
