Made it home what i found out
I got a 64.7 inch 7 rib belt from O'Riely's Plendy of tensioner left
also order a gates KO70644
Product Description
Features Advantages: Replaces belts on serpentine drives and other V-ribbed belt applications. Designed for small diameter pulleys, backside idlers and automatic tensioners. Belt construction eliminates noise, reduce tension loss and solve problem drives. Tensile members and rib reinforcement added for wear and crack resistance. Meets or exceeds SAE J1459 specifications. V-ribbed on both sides of the belt.
Belt / Sprocket Specifications
Effective Length (in): 64.44
Effective Length (mm): 1637
Number of Ribs: 7
Outside Circumference (in): 65
Outside Circumference (mm): 1651
Top Width (in): .947
Top Width (mm): 24
Customer Pack: 1.0
Standard Pack: 41
Product Attributes
Section: K
Weight
Weight (Lbs.): .44
K070644-GATES CORPORATION-Micro-V AT Belts
looks like a nice belt and it is tuck in the glove box
now i will get the v-belt
thanks you guys for the feed back......
