Coalman
- 0
- 0
- Paxinos Pa
I have a m35a3 and it wont turn over all it does is make a clicking sould at the firewall. I checcked the voltage and it is reading 23 volts at the starter . so I guess that rules out batteries. I did check the voltage at the solanoid on the firewall and it reads 23 volts on the one side and 9-11 on the other side when you hit the starter switch . How do I test the switch to make sure, and also could it be the starter ??? I tried bypassing the solanoid and nothing happens. I did take the solanoid out and was planning on replacing it first but they run over $100 bucks. So I was hoping to make sure what I needed rather than just putting parts on and guessing Thanks in advance
