M37 Restoration - Newbie Attempt
Carter
Delta, Pa.
Forgive my ignorance, but I have heard several references to a "third member" and am stumped. Can someone here enlighten me? Thanks in advance
Phillip
Phil, that's a regional term used to describe a vehicle's differential.
jrodjared
Baltimore, MD
Hey guys, derailed for a bit because I am trying to buy a house. Best part is it has a two car detached garage, so once the dust settles, let the fun begin. Muhahaha. I'm itching to get in there. More to come.
jrodjared
Baltimore, MD
IMG_1516.jpgIMG_1525.jpgIMG_1524.jpgIMG_1523.jpgIMG_1522.jpgIMG_1521.jpgIMG_1520.jpgIMG_1519.jpgIMG_1517.jpgIMG_1526.jpg
Rear axle assembly complete, moving on to the transfer case. All fluid drained and loaded up. That yellow canister is a heated pressure washer. It burns diesel and gets boiling hot. Quite effective.
jrodjared
Baltimore, MD
IMG_1645.jpgIMG_1652.jpgIMG_1651.jpgIMG_1649.jpgIMG_1648.jpgIMG_1647.jpgIMG_1646.jpgIMG_1650.jpgIMG_1644.jpgIMG_1653.jpg
More priming and prep. Taking pics of hardware as I take it off. These king nuts prove to be a real pain in the butt later on.
jrodjared
Baltimore, MD
Some transfer case prep and a before and after of some of the drive shafts yolks using my soda blaster. Pretty effective. New shifter rails for the transfer case too! Ohh, shiny. Disregard the photos of the brake lathe. I couldn't figure out how to delete them!
jrodjared
Baltimore, MD
IMG_1670.jpgIMG_1676.jpgIMG_1675.jpgIMG_1674.jpgIMG_1673.jpgIMG_1672.jpgIMG_1671.jpgIMG_1668.jpgIMG_1669.jpgIMG_1677.jpg
Working on the transfer case. All new bearings, races and seals. I re-coated the inside of the case to avoid sweating. Pricy, stinky and time consuming, but seems worth it in the long run. I came this far, why not?
jrodjared
Baltimore, MD
IMG_1695.jpgIMG_1702.jpgIMG_1703.jpgIMG_1704.jpgIMG_1705.jpgIMG_1706.jpgIMG_1707.jpgIMG_1708.jpgIMG_1709.jpgIMG_1710.jpg
Interesting trick I learned here in the first photo. We couldn't get the bearing on the shaft easily. The answer? Freeze the gear and shaft assembly (contract) and put the bearing in your toaster oven (expand). Slid right on :) Again, props to wayneh. Next photos are prepping the spring bolts and springs.
jrodjared
Baltimore, MD
IMG_1724.jpgIMG_1725.jpgIMG_1726.jpgIMG_1727.jpgIMG_1728.jpgIMG_1732.jpgIMG_1733.jpgIMG_1734.jpgIMG_1735.jpgIMG_1736.jpg
More transfer case work. Rebuilding this was a lot of fun. Not that hard if you are working with someone who knows what they are doing!
jrodjared
Baltimore, MD
IMG_1737.jpgIMG_1738.jpgIMG_1739.jpgIMG_1756.jpgIMG_1757.jpgIMG_1759.jpgIMG_1760.jpgIMG_1761.jpgIMG_1746.jpg
Transfer case again. I was missing a gasket from my set, so I purchased this gasket punch set at an auto parts store in their bargain bin for like $7. Then I got some gasket material, traced is, cut it out and punched the holes. Good as new!
jrodjared
Baltimore, MD
IMG_1777.jpgIMG_1778.jpgIMG_1779.jpgIMG_1780.jpgIMG_1781.jpgIMG_1782.jpgIMG_1783.jpgIMG_1784.jpgIMG_1785.jpgIMG_1787.jpg
My dad and I taking apart the axles. This was originally his truck. He didn't get to working on it quite as planned, and my mom threatened to get rid of it if I didn't do something with it! That's how I got roped in to this whole mess :)
