M38A1 Spark plug gap?
doghead
4 Star General /Moderator
1,179
NY
.030, I googled it.
F18hornetM
10
Ocean City, Md
Rule of thumb if gap is not known, is 90 degrees to center electrode. Of course proper gap is best, but if in a pinch, just make it square..it will work untill you can find proper gap. or forever..:beer:which ever comes first
F18hornetM
10
Ocean City, Md
Is it only fouling #4? i would suspect oil foiling vs fuel fouling. The needle and seat may be stuck, but usually if they are it would flood terriably and foul more than one plug. i would dissasemble carb and clean everything for the running rich problem. Of course in any issue should check compression etc, first, otherwise might be chasing your tail. Make sure engine is sound first. Then tune up. Just an idea..Good luck
