JAMartinJr75
- 0
- 0
- Fort Myer, VA
I am looking for the same TM. I need the one prior to the 2005 edition. That TM covers the MK64 MOD 7 which was changed to the MOD 9, after a MWO released in 1998. Thanks for the help guys.
email sentWould someone please send me PDF copies covering the M66 Mount installation? pedormont@hotmail.com
Thanks to all!
Paul
Welcome to Steel Soldiers! You not only need the gun ring and legs, but you also need a cab reinforcement plate installed in your cab if there isn't already one installed. This is critical because of the excessive weight of the ring and legs flexing the cab. You will destroy your cab if this reinforcement plate is not installed. You will also need instructions to install the ring. I have attached the USMC instructions for the 5-ton which are the same.Hello Fellow Steel Soldiers. I am new to the group and i have a 1983 AM general M35A2. I am looking for the M66 Gun Ring Mount complete with legs etc. to Bolt right to the truck. Thanks for your help
best Romano
