Willscustoms
- 0
- 0
- Palatka/St. Augustine Fl.
I need a few things for my 715 and need a little information.
Are the motor mounts on the Civ. and Mil 230 the same? If not where can I get Mil motor mounts?
My truck is converted to 12v and I want to retain the original BO lights. Can I just replace the bulbs with 12v bulbs and everything work properly?
I have a Delco HEI dizzy on it. Do i just order plug wires for the civ. model?
I have replaced plugs, cleaned the dizzy, rebuilt the carb. but my truck will not idle off choke. It runs excellent as long as it does not go below around 1000 rpm. Anything lower it will stall. it runs excellent with no valve noise or anything but will stall at idle. Any advice on this would be great.
Where is a good place to get brake parts?
