So having the truck fire-up, run well and actually driving it was the fun part. Now comes more fun. Here are the initial observations:
1) Rubber: Fuel filler neck (pictured below), hoses, belts, rubber cap thingy covering an opening on the side of the water pump that leaks like a sieve, etc.
2) Thermostat will get changed
3) Valve cover gasket is toast
4) Fuel System: Will need to clean the tank. An electric fuel pump was mounted to the frame. I mentioned in a prior post that the engine oil smelled like fuel. We were speculating that the electric pump had too much pressure and forced fuel into the oil. I'd like to replace the factory pump. Also, the fuel lines will get replaced.
5) Electrical: The electrical system was not our focus last weekend, but you can't miss the rat-eaten wires in the engine compartment
6) There are vacuum leaks to address
7) No breaks...
![Cool 8) 8)](https://www.steelsoldiers.com/images/smilies/icon_cool.gif)
The lever to engage the front axle is stuck with the axle engaged. This may be a problem in the transfer case.
9) General PMCS is in order (fluids, filters, grease, etc.)
10) I'm sure this list will grow before it gets shorter, and that's before the cosmetic stuff!
The fuel filler neck is cracked:
And here is the electric fuel pump:
