KTanis
- 0
- 1
- Columbia, NJ
Just picked up and M809 5-Ton Wrecker, Having trouble with the brakes. When you press the brakes pedal goes very low and the brakes don't work at all, but after pressing the pedal a few times the brakes lock up and won't release until you really stand on the pedal and then they release. The master cylinder was empty when i got it, but i don't see any leaks, i did top it off. Is it possible it has air in the system now from being empty? Where should i look first?
