Andydieselpower
- 3
- 18
- Owatonna, MN
I'm in the process of replacing my steering knuckle boot. After taking off the old boot and the boot/knuckle protector plate on the front of the axle I put some grease in the bottom grease zerk under the axle to see where exactly the grease from this zerk goes into the assy. At first it just squirted grease out of the flange where the grease zerk is held onto the bottom of the axle. I then reinstalled and tightened my two bolts that held on the front of the protector plate and then retried putting in grease only to have it squirt out of the sides of the flange again. Can I take this bottom plate off? I notice only two more bolts holding it on. Is there anything that is going to fall out or being held in that is held by this plate? I just want to clean the plate and reinstall so that the grease goes into the assy. Before the boot repair the zerk took grease fine and didn't purge out.
Thanks,
Andy
Thanks,
Andy
