dezert ratt
- 13
- 16
- menifee, ca
I pulled my truck in to the shop today to start working on the airpack rebuild, and check/ adjust all the brakes. I pulled the front tires off the truck, the pass front brakes are dragging so much, i can hardly spin with the wheel on the truck. Now i read up on the tm for adj. the brakes, and when i loosened up the 4 adj. on the pass front hub, the hub locked up completely. Here is where im baffled. I opened the bleeder for the wheel cyl, did not help. I messed with the adjusters, did not help. Now im wondering if the return spring is broken? How can i pull the hub/ drum off, with the brakes so tight? This is my 1st big truck, and its still new to me. Any and all help appreciated.
