M818 Milage
ARMYMAN30YearsPlus
Parkville, MD
If I was to drive an M818 bobtail and keeping it at moderate speeds what kind of milage would you expect to get. I am looking at the cost to do about 850 miles in one if I am getting it. Anyone with one of these please chime in I know the gasser M52 would only get about 3 to 4 MPG and it would lay a smoke screen behind it too.
cranetruck
75
Meadows of Dan, Virginia
According to the TM, you should get 4.0 to 4.5 mpg, but that's probably loaded, so figure 5 to 6 on the highway with one driving axle (recommended by yours truly)...
My XM818 W/W gets around 8 mpg bobtail if driven nicely. We got over 6 mpg flat towing another 5 ton tractor. and while flat towing those other tractors i was not real nice to it as far as fuel usage went. mine is turned up a little and will go thru a bunch of fuel in a hurry if not carefull.
73m819
325
gainesville, ga.
my old 52 m52 gasser got almost 6mpg bobtailing and NO smoke, sounds like youe gasser 52 is running rich
jwaller
19
Columbia, SC
I get about 5 with mine but I run it flat out on the governor with 1600's. about 4.5mpg loaded running with it on the floor.
Scrounger
66
Southern, Maryland
David, I have gotten as high as 11 MPG when I bobtailed up to Havre de Grace to pick up a generator trailer. And it’s been as low as 6.6 towing a 127 and grossing around 50K. I usually expect 8 to 8.5 when bobtailing it depends on traffic and weather. I have 11:00 X 20’s and try to maintain 2100 RPM on the open road.
halftrack
11
New Orleans, LA
That is more what I see with my M818 and towing the halftrack.
Westech
CPL
6,104
208
cow farts, Wisconsin
I get around 8/9 MPG in my 813. It has a brand new engine in it. I keep it about 2100 rpm and I think thats around 50/55 MPH. Even with my Honda in the back I was still getting around 8/9. In the Cummins it seams to do really well if you keep her ez and not push it really hard.
ARMYMAN30YearsPlus
Parkville, MD
Thanks guys:
I did think the M 52 was running rich because the fumes coming out on the road were driving my chase car crazy even at a hundred and fifty feet back. I like the cummins motors in the M818's we ran our M 915's with 400 cummins everyday for years and they just ran and ran. My thoughts are that if I do get one and have a long drive I would settle in at a lower RPM and just ride it home watching the gauges and stopping every 200 miles for PMCS.
