tcruwithme
- 20
- 18
- Eagan, MN
Hello,
I am not sure if this is the right place to post this request. If not, my apologies. I am trying to install a power steering kit taken out of an M818 tractor into my M35A2C. During the installation process, the steering bearing fell apart and the ball bearings are all over the place. I don't know if the upper steering bearing from the M818 is the same as on all other 5-ton trucks. It goes in between the inner pipe (threaded) and the external case of the steering column just before or below the steering wheel. Someone asked me if it had a spring inside it or felt on top of it - but I don't know as I didn't pull it out myself.
Can you tell by the photos if I am actually looking for the "upper steering bearing"? If so, does anyone know where I can get one of these?
