M880 with commo shelter
nattieleather
144
Cleveland, OH
I know the M882 was suppose to be the commo truck and many were done with a rack and antennas, but were S-250 type commo shelters used in M880s? And if so did the truck get a different number was it still the M882?
Thanks
Bob H
161
Huron National Forest, Michigan USA
Ok differences from a M882 (from memory)
Rear springs, overload setup like on a 1 ton
No Tailgate, but two angular braces which also keep shelter from sliding out
a "C" channel running across the front of the bed, to hold shelter down
Antenna do not mount on bed side like M882. (I think)
Either the 12v alternator is 100amp vs 60amp or the 24v generator is 100 amp vs 60.
Have to break out the manual I guess................
nattieleather
144
Cleveland, OH
Ah ok...So it would be set up very much like a M1028 CUCVs were. The big C channel that bolted to the front of the bed and then the two corner brackets in the rear. Sounds like I'd have to find a M884 instead of an M880 to do this.....
Now I just looked at the pics from the link above and the one truck with the commo shelter pulling a 3/4 ton gen trailer shure looks like it has a tail gate.
And according to that the M883, 884 and 885 were all set up for the commo shelter.
Bob H
161
Looked in da book
the 60 amp vs 100 amp is the 24v generator
The pic in the link might be an M880 with a shelter set in the back
can't see the channel up front in that pic.
I have not seen a M884 with a tailgate, maybe they did come with them, but it sure makes it hard to get in the back door.
I'll take a closer look at the M884 in the back yard , later today.
