nattieleather
- 143
- 63
- Cleveland, OH
Did you have the head side of the manifolds machined also to make sure you got a true seat and fit? Just wondering. Looking good. Keep up the good work!
Super hot here today but a lot accomplished on the 886. Correct gasket for the manifold finally showed up(mis sorted by ups)so I could finish the manifold install. It seems a non emission type is not available so I had to make a block off plate for one end, the manifold came with the other two necessary plugs. I have all the new exhaust in place just need to tighten it all up. Replaced the firewall side of the heater box and installed the new blower motor and fan. Also installed tow bar adapters up front just in case. Next on the list is to sandblast and prime in the box, way too hot to suit up today. Some exhaust part numbers, Y pipe 40405, tail pipe 45656, tail ext. 42499, manifold gasket set MS90460, LH manifold 674-233, muffler 18142. The pipe from the y pipe to the muffler is discontinued, I repaired mine by welding new pieces on each end or you could have one made at a shop. You will also need 2 1/4 and 2 1/2 clamps and my need a couple of universal hangers depending on the condition of them.
