JH1
- 5
- 18
- Seattle, WA
Y'all...
I have a M915 with the NTC400 engine. Don't know if it's a BC1 or BC3. Seems weak. Only develops 17 PSI of boost, and the manual says it should develop about 25 if running right. Have looked through the postings and see things about hot-rodding them for more power, but not seeing a general attack plan for isolating the low power problem. Some things that are obvious are: Clogged fuel filter, clogged air filter, collapsing fuel lines from tank to pump, incorrect valve timing, burnt valves, failing turbo, and incorrectly adjusted throttle linkage. I'm sure there are more. The TMs generally start by having you take out the engine. That's a bit ham-fisted. Is there a rule of thumb for what to check first, etc?
I can test for a fuel delivery problem if I know what the fuel pressure should be at the intake and output of the pump, but can't find that spec. There must be a vacuum spec for the area between the air intake filter and the turbo, too. That would tell me if the air filter is obstructing the flow.
Any help is greatly appreciated.
JH1
JH1
